engine maintenance access hole?
Old Dec 10, 2007 | 08:42 AM
imjrk's Avatar
Default engine maintenance access hole?
In the Chilton manual it says there is an engine maintenance access hole (or something similar)? Anyone be ale to tell me where it is located? Changing oil pump, timing belt, water pump etc. Engine will HOPEFULLY be out soon to accomplish this (replacing shot engine with JDM). '96 Accord VTEC automatic.
Also, fairly easy to pull engine without trans? Have all of the bolts out of trans to engine, I believe. Any advice on doing this pull? Looks like we need to slide it to the right as we pull it, after taking off the motor to strut tower mounting bracket out.
basket_case
Aug 17, 2012 08:21 PM
Reboticon
Aug 24, 2010 06:50 AM
stevolivin
Apr 14, 2010 01:30 AM
tcodi
Aug 12, 2006 11:33 AM
acalder
Jun 30, 2006 07:19 PM
