Engine problems that'll drive a man crazy
Old Sep 1, 2008 | 11:03 AM
hppygilmoregolfr
Default Engine problems that'll drive a man crazy
So I have a 92 accord that i'm trying to get started. I have replaced: fuel pump, fuel filter, spark plugs, wires, coil, distributor, ecu; checked and i have good spark on all plugs, also know that fuel is getting to cylinders. The only way we've gotten it to start is to manually retard the distributor about 15 degrees and then when the car starts, move the distributor back. Any ideas?
Old Sep 1, 2008 | 01:54 PM
Default RE: Engine problems that'll drive a man crazy
I would check all the fuses and look for the one to the ECU.
Also, check that your grounds are clean and secure in the engine. There is one on or near the thermostat housing.
Old Sep 1, 2008 | 01:59 PM
hppygilmoregolfr
I already checked fuses and i just checked my grounds also and i still have the same problem. thanks for your help any other ideas?
Old Sep 1, 2008 | 08:31 PM
You have replaced a lot of items, so lets just check the basics to get a car to run: Fuel, spark, compression, timing.
Fuel pressure should be tested with a gauge hooked up to the rail. Also, hook up a test light to the connector for each fuel injector. It should flash when you are trying to start the car.
For spark, a good spark would flash the light.
I would also turn the crankshaft to TDC and check that the camshaft timing marks are lined up.
Also check the compression on each cylinder.
hank97
Aug 31, 2014 10:30 PM
Levibyz
May 31, 2011 09:43 PM
deadaccord92
Nov 17, 2010 10:05 PM
pmatos
Apr 12, 2009 01:04 AM
remington870_20ga
Mar 25, 2005 01:32 PM
