Engine Speed Input Circuit
Old Oct 12, 2007 | 01:05 PM
Becker
Default Engine Speed Input Circuit
My 96 Accord Ex V6 hesitates or surges while driving (after its warmed up). During this time, the tachometer jumps all around. A few weeks ago my check engine light went on. The trouble code is P0725 - Engine Speed Input Circuit. The last honda mechanic I took it to simply "cleaned" off the dirty circuit (no discussion of repair/replacement), but the problems still remain and the light returned. They told me if the problem persists, that it "may" mean I need a new transmission. Yikes!I never got a straight answer or solution from them. Before I take it in again to someone more helpful, can someone tell me whether the issues may be related to the trouble code and whatthe actual issue may be? Thanks!
Old Oct 12, 2007 | 01:27 PM
00AccordLX5spd's Avatar
Registered User
Default RE: Engine Speed Input Circuit
Replace the ignition coil. There is something wrong with it internally. It is a common problem on the 95-97 V6 models. P0725 has nothing at all to do with the transmission. It is a coil fault.
Please look at this thread: https://www.hondaaccordforum.com/m_56200/tm.htm
You should be able to do it yourself relatively easily with a 10mm wrench. If you need more detailed instructons PM me and I will help you.
It only cost me about $75 to fix. Even if you have a mechanic do it, he should not charge you more than 1 hour or so for labor as it is super easy and only held in by 3 bolts with 2 wiresconnecting to it.
Old Oct 12, 2007 | 05:13 PM
Chiovnidca's Avatar
x2 put a coil on it
Old Oct 16, 2007 | 10:25 AM
Becker
Thanks for your help! I took it to my mechanic and told him I thought it was the ignition coil. He argued a little, assuring me it was my transmissioncoming apart and that I would have to do some "soul searching" as to what I would do with it from there. This is the what the previous mechanic that told me as well. I'm surehis stubborness had to do with the fact that I'm a young woman. Anyway, I left it there asking him to simply look at it and erase the code so I could pass emmissions. He called shortly after telling my he called his National Honda Database and they told him it was indeedthe ignition coil and not to touch the transmission. He said he had never seen an ignition coil throw such a code or create the hesitation. But he replaced it and its working fine. Thanks again for your help...it saved me from having to replace my transand from a lot of frustration with unanswered questions!
Old Oct 16, 2007 | 10:32 AM
falkore24's Avatar
Go back and tell him that with all of his experiance he was just[sm=owned.gif]by a young woman with no experiance at all! Maybe he should get off his high horse and start reading deserthonda's posts!
If his intent was to charge you thousands for a tranny, I'd report him to Honda.
BTW ---- DH is in AZ as well. I don't know if you are close to him, but I'm sure that he'd love to work with a HAF member! Also, he knows more about these cars then the designers!
Old Oct 16, 2007 | 10:33 AM
Registered User
Glad we could help! I am glad you got on here. If you had a new transmission put in there you would have wasted several thousand dollars and your problem would not even have gone away! I only wish you had lived nearby or I would have done the labor for you for free on a weekend.
Old Feb 26, 2019 | 11:15 AM
Brandon Robertson's Avatar
did your rpms on your cluster gauge not work either?
piconrule
Jul 24, 2009 02:38 PM
Brian619
Dec 29, 2007 11:46 AM
miks
May 15, 2007 01:46 AM
HankR
Dec 20, 2006 04:00 PM
Tuan
Aug 7, 2006 01:31 AM
