Engine stalls at light PLEASE HELP
Old Jul 18, 2007 | 09:08 PM
lionj
Default Engine stalls at light PLEASE HELP
Hi,
I'm new to this forum, I have a 98 accord LX and it stalls intermittingly at stop lights, when trying to start it will turn over but won't stay on after a few trys and pressing gas it will start and work perfectly. This doesn't happen all the time, but is a problem as cars blow me down to get out the way. I don't know what to troubleshoot, any assistance is greatly appreciated.
Old Jul 18, 2007 | 10:54 PM
Default RE: Engine stalls at light PLEASE HELP
How's your tune-up stuff? Spark plugs, wires, timing, idle setting, valve adjustment?
It sounds like you need to cleanyour IACV &adjust the base idle speed, but any of those other things can get involved to confuse the issue.
Old Jul 19, 2007 | 02:35 AM
edgarm
[8D]
Get OBD11 CODE CHECK from there you will see what is the trables with your car.
Get tool loan from Auto Zone part then post your troble code ?###.
No more squandering ??????????.
If is code P0401 check your EGR valve port but find out what is the code in the OBD11 first.
Old Jul 19, 2007 | 08:46 AM
smaglik's Avatar
ORIGINAL: edgarm
[8D]
what?
Old Jul 22, 2007 | 12:15 PM
lionj
Hi,
I ran a obdII code and came up with PO402, can anyone help me with this? also what is the IACV?
Old Jul 22, 2007 | 03:11 PM
Chiovnidca's Avatar
ORIGINAL: lionj
Hi,
Maybe you mean p0401 or p0420?
Old Jul 22, 2007 | 11:21 PM
IACV = Idle Air Control Valve.
On a 4-cyl engine it's bolted to the underside of the throttle body. Not sure about a V-6 but you didn't say what you have...
It's job is to bypass a little air thru the throttle body, as controlled by the ECU to hold the idle steady.
bathsaltzombie
Oct 2, 2014 09:24 AM
Meklin89
Jul 14, 2013 07:03 PM
lilskydiver
Sep 10, 2009 06:45 AM
NexusUA
Aug 12, 2008 12:15 PM
stewart609
Mar 25, 2008 07:02 PM
