engine still vibrating
Old Jun 18, 2011 | 10:28 PM
tycobb280's Avatar
Default engine still vibrating
I've had a pretty bad engine vibration problem for a while now. I did the EGR port clean a while back, it didn't help at all. I just recently changed the EGR valve and fuel pressure regulator. Nothing has helped. Any suggestions as to what might be causing it? It's a 93 ex.
Old Jun 18, 2011 | 11:15 PM
Tek310's Avatar
none of those things would have anything with engine vibration.
vibration would come from one of these:
tire balance
alignment
worn engine mounts
worn suspension bushings
worn tires
low idle
do you have any check engine lights? possibly misfiring
Old Jun 18, 2011 | 11:20 PM
Do you get the vibration at idle, or only when driving?
Old Jun 20, 2011 | 10:28 AM
tycobb280's Avatar
Well I was given false info then. I read on here somewhere that the egr port clean was supposed to help with vibration. The fuel pressure reg wasn't really something I did to resolve the vibration. It is engine vibration, so it doesn't have anything to do with suspension bushings, tire wear, alignment or anything like that. It happens a little at idle, t happens mostly under acceleration. The front mount does look kind of bad and is easy to get to, so ill try that and see what happens.
Old Jun 20, 2011 | 02:07 PM
Rice4Life's Avatar
im almost sure its an issue with the engine mounts
abhijitgp
Aug 28, 2009 10:43 PM
Revolutionary
Nov 13, 2007 03:42 PM
ckeegan
Jul 28, 2007 09:48 AM
R34Accord
Mar 22, 2007 09:01 AM
R34Accord
Mar 20, 2007 11:27 PM
