engine swap
Old Oct 7, 2013 | 08:00 PM
my honda1's Avatar
Default engine swap
am putting a 2.2 vtech out of 95 honda accord and putting it in my 96 accord non vtech is the wireing in the engine the same cuss my non vtech has coil my new one dont any help would be nice
Old Oct 8, 2013 | 09:31 AM
Roader's Avatar
Your '96 OBD2 car has TDC & CKP sensors bolted to the oil pump housing; the '95 engine has those sensors in the distributor. For the least amount of wiring changes, you can use your '96 distributor but you'll have to swap out the oil pump housing and use the '96 crankshaft sprockets: OBD2 sprockets
Old Oct 10, 2013 | 05:57 PM
And check local laws....if you have to stay ODB-II, you have a bit more work to do.
D-Rod33
Nov 2, 2011 07:38 AM
hondahead23
May 9, 2011 08:55 AM
mfskarphedin
Jun 6, 2010 09:33 PM
StatzFinest
Feb 10, 2008 11:32 AM
