Exhaust manifold heat shield
Old May 23, 2007 | 12:22 AM
Drpepper's Avatar
Default Exhaust manifold heat shield
Doe anyone know if I will damage anything if I remove the heat shield over the exhaust manifold and run it until I can find a new one?
The bottom bolt is broken inside the manifold, the top right bolt hole is broken on the shield leaving only one fastening point on the shield and it makes a terrible vibrating noise when the engine idles at lower speeds.
Old May 23, 2007 | 08:12 AM
foxracing31702's Avatar
Default RE: Exhaust manifold heat shield
i dont do it personally and havnt heard anything about running with out them...but i have seen people that run with out them....
Old May 23, 2007 | 10:03 AM
People have removed them without problems. Keep an eye on heat damage to your radiator fan & nearby plastic stuff. If you live in the Sahara where it's always really hot, then be especially careful... But it'll probably be OK.
Alone
Sep 29, 2014 04:48 PM
ajohnson
Feb 20, 2014 09:47 AM
sp33dd3mon343
Mar 23, 2012 06:34 PM
Peli
Jul 18, 2011 10:12 AM
JerseyTuscani
Jul 2, 2007 05:21 PM
