exhaust question for diy
Old Dec 28, 2009 | 05:33 PM
freeze101
Exclamation exhaust question for diy
Hi Everyone
I wasnt sure whether to put this in this section or the exhaust section so sorry if its in the wrong one.
I have been searching for hours and I cant seem to find anything that explains to me how to remove the rear and middle box on my 1999 2.0 Accord.I have done many exhausts on other cars I have owned but they have all been simply bolt on back boxs and stuff and the one on my Accord looks like nothing I have seen before im sure its easy when you know how I guess my real question is how do you remove different parts of the exhaust system are they nut and bolts or something else that has to be cut off or something ?
thanks for reading
Freeze
Old Dec 28, 2009 | 09:18 PM
kris_loehr's Avatar
Help me out. What are you calling a box? I looked at the exhaust for your year Honda on the Majestic dealer site. It is just a convertor toward the front with a long B pipe and then the muffler with welded tailpipe. It looks to have either studs or nuts at each joint with a gasket. It takes apart with a short 90 in front of the muffler, then next way up by the front of the car B pipe to convertor.
Old Dec 28, 2009 | 09:58 PM
freeze101
Im sorry here we call the silencers/mufflers (box's)
I need to replace the centre and rear silencer so my question was how to remove it from the cat as they dont seem to be bolts ??Their is certainly three studs of some kind but they do not look like they have a nut on ore unbolt out themselves ??
thanks for the reply I appreciate it
Old Dec 29, 2009 | 01:00 AM
kris_loehr's Avatar
Majestic Honda lets you order on line and you can look up your parts and see the illustration but it is for a USA vehicle. They show bolts and lock nuts at both ends of the convertor..
Old Dec 29, 2009 | 01:02 AM
finch13's Avatar
They should be studs and nuts at the cat. Possibly bolts with springs around them too. You may want to heat them with an oxy/acetylene torch so you don't break a stud.
Kris, it's a 2.0, meaning it's not from the U.S.
Old Dec 29, 2009 | 06:20 AM
freeze101
Yeah your 100% correct about it not being from the U.S and your answer is pretty much what I would have said but these are not studs/bolts and nuts they actually look like they have been pressed in or something at the factory I am going to clean it more and try to have a better look but it looks like I am going to have to cut them off.
Thank you for your reply though
Freeze
Old Jan 4, 2010 | 07:15 AM
Generally they have a donut gasket & spring-bolts so the exhaust can flex at each joint. If you can't get the strange factory bolts, I've been able to use long normal bolts with several nuts & fender washers to do the same thing.
DMarley
Aug 20, 2013 10:22 PM
mayot
May 12, 2012 08:49 PM
insadj05
Sep 12, 2009 01:27 PM
markus9175
Mar 27, 2009 10:35 PM
andre4999
Feb 23, 2007 10:11 PM
