exhaust quick question
Old Dec 22, 2011 | 10:42 AM
Honda4me's Avatar
Default exhaust quick question
Hi guys,
went under the car today to find out where the rattling noise is coming from, had no luck as all bolts and everything is pretty tight enough, looked at down pipe and found that the meshy thing around this box is loose/broken on one end, should it be loose/broken??
I get lots of rattling and clicking noise when the engine is cold, but once warmed up only rattling noise from back of the car, only when I hit a none smooth road surface
Old Dec 22, 2011 | 10:59 AM
bigpat's Avatar
Almost A Senior Member
That looks to be a heat shield for the euro model catalytic converter...I doubt it should be loose/broken/or rattling.
Old Dec 22, 2011 | 03:52 PM
Honda4me's Avatar
the actual catconverter is after this section
Agree, it shouldn't be loose/broken, I will take a pic of it once successfuly removed.
Old Dec 26, 2011 | 09:57 AM
Honda4me's Avatar
that messhy thing is a flexi exhaust pipe, it's there to stop vibration and noise. Can do without it, but they are cheap as chips, yet needs welding etc with the new one. It also comes in as a built in with new down pipe.
The question is, would a split exhaust pipe make any difference in terms of fuel consumption?
I have no trouble gaining and retaining speed, just that I get only around 25mpg City run, not that I am heavy footed.
Old Dec 26, 2011 | 02:21 PM
You'll need to fix but you know that.....I don't think you'll pass MOT (?) like that.
There is prob an impact to MPG, the secondary O2 (post cat) is getting a false reading if extra air is getting in.
As for the rattle, double check the "shields" around the converter, see if they are loose....push/pull on the four corners.
Old Dec 26, 2011 | 02:35 PM
Honda4me's Avatar
cheers for the advise fella, will double check the shields.
on my to do list to change the front drop pipe next week.
will let ya know if the MPG increases.
Joyce.Tyler541
May 17, 2015 09:58 AM
Stopormymomwillshoot
Aug 29, 2010 06:18 PM
get'er go'in
May 4, 2010 12:33 PM
ttwista
May 19, 2009 08:35 PM
dnask8ter
Jun 3, 2007 10:48 AM
