Extended oil use and consequences.
Old Oct 21, 2011 | 05:07 PM
  #21
RA1525's Avatar
Originally Posted by irhunter
Is the increased engine temperature reflected on the water temperature gauge?
I have read any number of posts by people running synthetic oil longer than the car manufacturer specifies (for dino oil, anyway) and have never read of increased temperature. I would be tempted to keep track of head temperature with an IR thermometer and if I was getting a considerable increase I'd do something different (change the oil more frequently or switch to some other oil). Extra heat can't be good.
I have heard reports of oil leaks being worse with synthetic.
For what its worth, the only data-based study of synthetic oil I have read was done many years ago by the Consumer's Reports people. Their methods seemed really solid to me. They ran a bunch of taxis 70k miles and measured engine wear before and after. They concluded synthetic oil was a waste of money. The suggested: use dino and change it when the car manufacturer suggests. That is what I have done for a really long time with many high-mileage cars and trucks.
What is an acceptable head temperature on an aluminum head?
Old Oct 21, 2011 | 06:53 PM
  #22
UhOh's Avatar
Originally Posted by landlover
at about ten thousand miles the car takes a split second longer to start which I attribute to thicker oil "viscosity"
but all the tests that come back say it's within acceptable limits.
very, very few of us have ever had our oil analyzed. Could you educate?
So would you post up:
1) an image of the sample submission form, <what information you send in> and
2) an image of one actual analytical lab results form? <what information you got back>
Thanks.
Old Oct 21, 2011 | 07:13 PM
  #23
UhOh's Avatar
What changes at four thousand miles take place to change the oil?
Beats me. And again, I'm not saying change to what I do; these are strong motors they'll run whenever ... That said --->
My experience with aging of oil is only qualitative, the engine feels a little bit more sluggish. I drive a 5sp, but don't know if that's relevant or not.
After the change it feels better - can tell difference if change is at 4000 miles; can't tell if change at 2500. Nothing more than that.
So I add 1/2 qt at 2000 miles to replace loss, and change at 3000 - 3500. nothing fancy.
222,000 mile, 1993, 5sp., no engine work.
Old Oct 21, 2011 | 08:06 PM
  #24
bigpat's Avatar
Almost A Senior Member
I know that conventional oils become acidic with time, especially if not driven regularly. This is an issue in winter months for my friends in Mammoth Lakes (Eastern Sierra Nevada mountains)...They ski all winter and ride the bus to work.
Old Oct 22, 2011 | 12:14 AM
  #25
RA1525's Avatar
Thanks.
You read my mind, been having problems reducing the file size to put on here. Problem with Reader, hope to fix or have an alternative soon. Please check back.
Old Oct 22, 2011 | 12:18 AM
  #26
RA1525's Avatar
Smile
Keep it coming all, more information, don't be shy.
Old Oct 22, 2011 | 11:39 AM
  #27
Tek310's Avatar
operating temp..
11_22_1992
Jun 19, 2015 12:20 PM
HondaAficionado
Nov 30, 2010 09:24 AM
DaIna-Kelela
Dec 10, 2009 08:37 AM
dinzer
Jun 13, 2005 10:38 PM
tam
May 22, 2005 11:44 AM
