F22a6 engine with a F23a5 wire harness
Old Nov 14, 2020 | 08:46 PM
Bryce Red Cumberland's Avatar
Default F22a6 engine with a F23a5 wire harness
How can I make the f23a5wire harness and ecu work with a f22a6 engine
Old Nov 15, 2020 | 11:39 AM
Can you give us a little more information about your vehicle, like year, make, model, engine, transmission. Also, what is the vehicle information of the donor car, and what parts have you installed into your vehicle?
Old Nov 15, 2020 | 12:45 PM
Yeah I have a 98 accord dx manual trans 98wire harness and ecu and 93 accord f22a6 engine manual is what I got the engine out of
Old Nov 15, 2020 | 12:47 PM
Old Nov 15, 2020 | 06:52 PM
Probably the easiest way to wire up the engine is to find a 93 wire harness and a 93 ECU.
You'll have to do some homework to use your current planned setup. The one issue I can see is that the 98 accord is OBD2 and the 93 engine is OBD1, so you may be missing some sensors. I'm also not sure how efficiently the 98 PCM will run a 93 accord engine.
You may be better off using a 96/97 DX manual accord PCM, because the wire harness will be obd2 and the 96/97 is mapped for a 2.2L (f22 series) engine.
Old Nov 16, 2020 | 11:43 AM
The Toecutter's Avatar
Also, there's a difference in the injectors, as the 93 uses a resistor pack, while the 98 doesn't. Also like PA said you might need to do an ECU change, and swap some sensors.
Sparky1620
Jul 25, 2018 10:45 AM
Jacob305
Jun 24, 2013 04:54 PM
Jap.Doe
Jan 7, 2012 08:06 PM
ryder_kid
Oct 12, 2011 09:02 AM
cajeffus
Apr 26, 2011 05:00 PM
