Failed smog again 99' honda accord ex 3.0 vtec
Old Sep 23, 2013 | 02:20 PM
jsharp's Avatar
Exclamation Failed smog again 99' honda accord ex 3.0 vtec
Hello everyone, we'll I failed smog again if any one can lead me to the right direction would be much greatful. I have a 1999 honda accord 3.0 vtech 197,000 miles runs really good
first readings: Took car not very warm
15 mph 1725 rpm co2 (%) meas 14.6 02(%) meas 0.18 HC(ppm)meas 30
CO(%) meas 0.01 NOx (PPM) 688 I failed NOx
25 mph 1664 rpm co2 14.54/o2 0.06/HC 20/ COo.25 / NOx 238 passed
As you can see I failed only at 15 mph with NOx being higher than max
what I did after first attempt
1. changed oil,spark plugs,cleaned egr valve and used seafoam to clean injectors put the rest in the tank.
2. I drove car for a week and tried testing again with engine warm this time.
3. I still failed Nox at 15 mph and looks like I barely passed HC
4. second readings 15 mph CO2 0.17--HC 54 max 54-- CO 0.00--failed Nox 499 max 430 closer
25 mph CO2 14.6 -- HC meas 35 max 37 close--CO 0.00-- NOx meas 538 max 717 close but this time it was higher than first attempt. over all 25mph passed
Old Sep 23, 2013 | 06:26 PM
Wazari's Avatar
High Nox readings are usually result of a worn out or faulty catalytic converter or EGR system.
Old Sep 24, 2013 | 12:45 PM
Roader's Avatar
Was the EGR passage cleaned too? Requires intake manifold removal:
www(dot)youtube(dot)com/watch?v=HRp6RWZ1egM
torresusmc
Jun 12, 2013 05:28 PM
9DEX
Nov 5, 2011 10:21 PM
slloth
Apr 11, 2009 11:17 PM
micahjames
Mar 20, 2007 02:16 PM
jetblack3s
Nov 25, 2006 04:38 PM
