Fan Switch problem
Old Nov 5, 2007 | 12:11 PM
tomcar
Default Fan Switch problem
I have a 2002 Accord LX 4 door 4 Cyl. with 75,000 miles (first honda) The Fan switch for heat?ac
will not work in the first two speeds. Only at setting 3 and 4 will fan blow air.
Can this be repaired? or must the whole control panel need to be replaced?
Thanks.
Tom
Old Nov 5, 2007 | 01:07 PM
sir_nasty's Avatar
Default RE: Fan Switch problem
typically it's just the switch itself, you can test it by pulling the panel out, switch it to one of the first settings and see if any power is going out, if power is going out then it's a sensor at the blower motor (highly unlikely) if not then it is the switch
Old Nov 19, 2007 | 02:42 PM
tomcar
Hi. Started to get access, so I can test fan switch. Have removed two screws from bottom of panel.
(under radio) Removed clock, and removed single screw. Unable to easly remove panel
around the top vents. Is this a pop out, Or are there screws?
Thank-you in advance.
Tom
2002 Black Accord 4 Door Auto, w/ 75,000 miles
Old Nov 19, 2007 | 02:44 PM
sir_nasty's Avatar
Check this out, it should be VERY similar to your car (the 2000 that is)
http://www.installdr.com/InstallDocs/Honda/Accord.html
Old Nov 19, 2007 | 03:21 PM
deserthonda's Avatar
it could also be a bad blower resistor.,,, I have seen a lot of those go bad and not too may switches
Old Nov 19, 2007 | 06:12 PM
Chiovnidca's Avatar
It's most likely the blower resisters. It's very rare to see a bad fan switch on a honda.
Old Nov 19, 2007 | 07:23 PM
And...
Those resistors are added in stages. Its absolutely CLASSIC for a bad resistor, when it works on all higher speeds & doesn't work on lower speeds.
Old Dec 4, 2007 | 01:32 PM
tomcar
I found that the fan switch is ok. Where would I look for the resistor (s) ?
Are they under dash, or hood?
2002 Accord 76000 (took 700 mile roadtrip over Hoilday Runs Great)
Thanks
Tom
Old Dec 4, 2007 | 04:25 PM
sir_nasty's Avatar
they are located on the blower motor itself I believe
Old Dec 4, 2007 | 07:01 PM
HondatechAV6's Avatar
agreed. replace the blower motor transistor.
