Fan Switch problem
I have a 2002 Accord LX 4 door 4 Cyl. with 75,000 miles (first honda) The Fan switch for heat?ac
will not work in the first two speeds. Only at setting 3 and 4 will fan blow air.
Can this be repaired? or must the whole control panel need to be replaced?
Thanks.
Tom
Thanks.
Tom
typically it's just the switch itself, you can test it by pulling the panel out, switch it to one of the first settings and see if any power is going out, if power is going out then it's a sensor at the blower motor (highly unlikely) if not then it is the switch
Hi. Started to get access, so I can test fan switch. Have removed two screws from bottom of panel.
(under radio) Removed clock, and removed single screw. Unable to easly remove panel
around the top vents. Is this a pop out, Or are there screws?
Thank-you in advance.
Tom
2002 Black Accord 4 Door Auto, w/ 75,000 miles
Tom
Check this out, it should be VERY similar to your car (the 2000 that is)
http://www.installdr.com/InstallDocs/Honda/Accord.html
