Finally got it running after two years and now no lights 1992 lx
Old Jun 9, 2013 | 04:02 PM
phantomgrey92's Avatar
Default Finally got it running after two years and now no lights 1992 lx
So I finally finished up my five speed conversion and now that its running I have only my upper left parking light and my lower right bumper light and tail lights with high beams. My right parking light and left bumper light don't work nor do my low beams. All fuses and relays are good I need help
Old Jun 9, 2013 | 04:21 PM
Check for 12v at the light fixture. If 12v missing, either wiring or switch issue, if fuses are OK.
Old Jun 9, 2013 | 07:45 PM
Where exactly are the grounds for the headlights? I did have the entire front end pulled apart so did I miss replacing a ground?
Old Jun 9, 2013 | 08:26 PM
There is a ground bracket that bolts to the sub-frame under the bumper. There should be one on the passenger and driver's side of the car.
Old Jun 9, 2013 | 08:59 PM
For the 92 Accord, the ground used for the left and right low beams, and right front side marker is ground location G201; located on the right side of the engine compartment (see attached pic.). Check along the ground wire and the grounding point. -- There is a high possibility it is the ground or wiring due to them sharing the common ground.
The left bumper light is probably a separate wiring or bulb issue.
Attached Thumbnails Finally got it running after two years and now no lights 1992 lx-ground-g201.jpg
Old Jun 9, 2013 | 09:09 PM
well I am convinced that that ground is my issue, I will have to wait a day or two to find out tho, work first ya know
black94EX
Feb 20, 2012 01:11 AM
DisplacedMic
Feb 14, 2011 07:25 AM
Calgary Rob
Jun 25, 2010 01:20 AM
90accord90
Jan 25, 2010 03:28 PM
thunder_x
Jan 4, 2009 01:25 PM
