First really cold day here, clutch coming up slow.
Old Jan 7, 2014 | 09:43 AM
sona1111's Avatar
Default First really cold day here, clutch coming up slow.
Hello again, its been a little while now. Today marks the coldest day we have had here in new jersey for quite a while. (I am sure it is even worse elsewhere). After getting the car started the clutch pedal came up in about 1-1.5 seconds sticking somewhere which felt to be about in the middle. This is the first time this has ever happened. I started attempting to drive and I was thinking about dropping off work and going to a mechanic but I was not sure they were open so I just went ahead and drove anyway. (heh). In any case I guess that was the right choice because a little while after the engine finished warning up the clutch seemed to return at back to normal.
Is this something I need to get fixed right away? What is the first repair I should make to attempt to stop this from repeating?
Thanks.
Old Jan 7, 2014 | 11:14 AM
My first thought is how long has it been since bleeding your brakes & clutch, to get fresh fluid in there?
Brake fluid absorbs moisture, lowering the boiling point and raising the freezing point. Get some water in there and maybe?? the fluid is getting just a bit slushy.
First thing I'd do is bleed fresh fluid into there. Don't forget to do the same for your brakes...
Old Jan 7, 2014 | 12:10 PM
neo31ny's Avatar
Mine did the same thing this past week. I think the fluid gets thick in the cold weather(we had -20's degree weather here). I always warm my car up at least 15 minutes before I go anywhere when it's cold. After warming up my pedal went back to normal. I plan on changing/flushing all my fluids when warm weather gets here but I think when it gets that cold the fluids are going to thicken up no matter what. I suggest letting your car run before driving it.
Old Jan 8, 2014 | 08:47 AM
sona1111's Avatar
Hey guys, thanks for the info, I will definitely flush the system if I can find someone to help me.
Have an awesome day.
Aug 21, 2013 05:41 PM
wings
Jan 13, 2012 11:31 AM
Tek310
Sep 7, 2011 08:25 AM
WhiskeySlick
Jul 31, 2011 03:39 AM
tamb
Jul 21, 2006 01:05 AM
