FIT Valve question...tightening or loosening ?
Old Sep 29, 2014 | 11:21 AM
Alone's Avatar
Default FIT Valve question...tightening or loosening ?
What is the correct adjustment for adjust the FIT valve ?
Should I tightening it til it snug or loosening ?
what's the difference between tightening and loosening it ?
I haven't noticed any differences at all with tightening or loosening.
Old Sep 29, 2014 | 12:13 PM
Fast Idle Thermo (FIT) valve should only have an impact on idle speed when engine is cold. It increases idle speed by allowing air to bypass throttle plate when engine is cold. It should close as engine warms to have no effect. If you tested on a warm engine, you would not see any affect of adjustment unless the FIT was leaking initially.
Improper adjustment would allow increased idle speed of a warm engine. As long as it's snug, it should seal when engine is warm.
MessAround
Nov 3, 2013 04:25 PM
Starps
Jan 18, 2012 03:02 PM
06ex24
Dec 14, 2009 09:16 AM
mxl360
Apr 30, 2008 07:52 AM
wkugler
Jun 29, 2006 12:27 PM
