Fixed the codes and wierd noise
Old Feb 11, 2012 | 02:06 PM
bostongrun's Avatar
Default Fixed the codes and wierd noise
I was getting codes 300 through 306. The car idled really crappy.
First, I did a half a_ _ fix of the egr passage. I did not remove the throttle body and lifted the upper plenum and reamed out the passage with a pipe cleaner and did not replace the gaskets. It ran a little better but the codes came back. I redid it the right way, I even washed the intake manifold out in the sink like the TSB says. I also reamed out the hole with a larger drill bit.
The chirping noise turned out to be a loose power steering belt.
Now I am good to go.
Old Feb 11, 2012 | 02:22 PM
I bet it feels good......
stevepasq
Sep 12, 2010 01:12 PM
wetwilly2256
Jan 9, 2008 03:51 PM
Slowaccord
Aug 22, 2007 06:37 PM
mig25
May 24, 2007 03:50 PM
nixalot
Aug 10, 2006 04:54 AM
