Fixing a honda that doesn't start but cranks
Old Oct 19, 2014 | 07:04 PM
KingReset's Avatar
Default Fixing a honda that doesn't start but cranks
HERE IS THE ALBUM OF ALL THE PHOTOS I TOOK! PLEASE VIEW THEM.
So recently, we bought a 1995 Honda accord LX 2.2 L for 100 dollars from our friend.
He said that his car doesn't start but it cranks. And it all of this happened when he tried cranking up the car on day and it wouldn't start.
So when we recieved it, we checked for everything including if the timing belt works, distributor, fuel pressure ..etc then when we got to the sparkplugs - we took out all 4 sparkplugs and the last sparkplug was damaged. - it looked like it's been smashed by something.
Here is a picture -
More pictures are in the photo album.
Then we opened up the head cover and we noticed that the last that one of the intake valve springs were broken for the last cylinder where we found the broken sparkplug
-Name:  ck1bb6Z.jpg
With that, the two exhaust valve springs were more compressed / in than the other exhaust valves for the other 3 cylinders.
After that, we decided to open take out the cylinder head to see underneath.
We found out that the last piston was slightly cracked.
We took a look under the cylinder head where all the valves were and the last valve is really messed up. The valves rods are bent and everything looks really messed up.
The last piston
Under the cylinder head (for the last piston) -
Any ideas what we should do now? We want to fix it up with minimal $$ spent.
Every stuff for the cylinders look fine except for the last one.
http://imgur.com/a/jA17f
^ All the pictures that I took.
Old Oct 19, 2014 | 08:04 PM
shipo's Avatar
Buy a used engine; they are reasonably plentiful and relatively inexpensive.
Old Oct 19, 2014 | 08:19 PM
KingReset's Avatar
I think all of this happened because the intake valve spring broke and caused a loose in the intake valve and rod and the piston slammed into that causing all of this?
I mean the timing belt is fully intact.
What we're thinking of doing is putting a new piston in from the junkyard and buying a new cylinder head..
Last edited by redbull-1; Oct 19, 2014 at 08:40 PM. Reason: Same/similar posts in multiple threads merged. Same photos deleted.
Old Oct 19, 2014 | 09:00 PM
shipo's Avatar
It's most likely better/faster/cheaper to buy the whole motor.
Old Oct 19, 2014 | 09:05 PM
I think that you are right about what happened. Broken spring, then the piston bent the valve and smashed into your other valves. This mess broke the piston.
You might want to look for a used engine. Search car-part.com for junkyards with your engine. You can search by price or distance. You may be able to find a low mileage engine for a decent price. You will find that rebuilding the top end and repairing pistons may get expensive.
How many miles are on the current engine?
Old Oct 19, 2014 | 09:55 PM
KingReset's Avatar
196k miles
My dads seriously thinking just to replace the piston and cyl head lol.
Old Oct 20, 2014 | 12:26 AM
shipo's Avatar
Originally Posted by KingReset
196k miles
Bad idea unless you want to spend more money and have a car with an engine which most likely vibrates and burns lots of oil.
Old Oct 20, 2014 | 06:37 PM
I have to agree with the others - even if you replace the piston and rebuild the head, it might work but you have to deal with "unknown" issues - you never really know how it ran before this happened.
A replacement F22 engine should not be that much - do the maint items (t-belt, balance belt, seals, ect before install).
Now if you want to really go there, the F23 engines (6th gen accords) will swap in as well. You didn't give, or I missed it, the trim level of your car so there might be a bit more to that swap.
By far the F22 replacement is a simple plug and play - the F23 is a bit more.
lovemyoldaccord
Nov 1, 2014 09:42 PM
JDBeazy
Oct 30, 2014 02:43 PM
jbchdclark
Aug 31, 2012 08:14 PM
frankferry
Jun 8, 2012 10:23 PM
Spectre
Jan 17, 2010 06:08 PM
