Fluctuating RPMs
Old Dec 22, 2006 | 10:57 PM
wietgr's Avatar
Default Fluctuating RPMs
I have a 94 EX 2.2L w/ manual trans, and latley when i start my car the RPMs will be running at 2000 but as soon as i hit the acceleator pedal they fall back to 750 and then fluctuate from 750 to 2000 until normal operating temp. Im thinking it could be a vaccum leak. Any ideas? Thanks!
Old Dec 23, 2006 | 02:25 AM
hondadude's Avatar
Default RE: Fluctuating RPMs
Be sure you are full of coolant and block burped thru the 12m bleed screw at the T-stat housing.
2nd would be to open the top of the FITV and turn the nylon 'split screw' in a couple turns or until no air by passes when the engine is warmed up.
Old Dec 24, 2006 | 12:53 AM
wietgr's Avatar
coolant level is good and the system has no air pocket in it
Old Dec 24, 2006 | 04:16 AM
YeuEmMaiMai's Avatar
take the idle control valve off, clean the screen and valve with throttle body cleaner
Old Dec 24, 2006 | 02:47 PM
deserthonda's Avatar
on top of those suggestion,, make sure that there are no vacc leaks, chk to see if the adjustment screw has backed out , turn the screw in see if that helps
adamc44
Jul 13, 2008 10:37 PM
Flatline1121
Jun 29, 2008 01:24 AM
d_10
Apr 27, 2008 08:24 PM
HondaPhyco
Mar 4, 2008 08:55 PM
AKcord
Mar 29, 2007 01:44 AM
