Fog lamps ?
2015 Accord Sport
Am considering changing the white fog lamps to amber, I've not looked yet, but was wondering how much effort/trouble it is to change the bulbs.. will be keeping the clear lenses. And, in your opinion, will I see a noticeable difference in practicality by going from the white to the amber? Any thoughts and/or suggestions are appreciated. Thanks
You need to pop all the plastic push style clips on the lower cowling cover that protects the engine and transmission from road debris. Once you get that pulled down you should be able to reach in there to remove the bulbs. The only thing that I can suggest is to check your local laws and see if there are issues with amber fog lights.
Refer to the owner's manual for bulb replacement of factory installed fog lights.
For factory installed fog lights; driver's side bulb replacement, involves removing one screw from bottom and prying out lenses assembly from front to replace bulb. For passenger side, small access cover at bottom is removed to access bulb from underneath.
