Fog lamps ?
Old Apr 30, 2015 | 06:46 PM
Prospector's Avatar
Default Fog lamps ?
2015 Accord Sport
Am considering changing the white fog lamps to amber, I've not looked yet, but was wondering how much effort/trouble it is to change the bulbs.. will be keeping the clear lenses. And, in your opinion, will I see a noticeable difference in practicality by going from the white to the amber? Any thoughts and/or suggestions are appreciated. Thanks
Old May 1, 2015 | 05:24 AM
Turtlehead's Avatar
You need to pop all the plastic push style clips on the lower cowling cover that protects the engine and transmission from road debris. Once you get that pulled down you should be able to reach in there to remove the bulbs. The only thing that I can suggest is to check your local laws and see if there are issues with amber fog lights.
Old May 1, 2015 | 11:43 AM
Prospector's Avatar
Thanks, Turtlehead
Amber is ok in this and surrounding areas, blue and/or red is not allowed
Old May 1, 2015 | 11:50 AM
Refer to the owner's manual for bulb replacement of factory installed fog lights.
For factory installed fog lights; driver's side bulb replacement, involves removing one screw from bottom and prying out lenses assembly from front to replace bulb. For passenger side, small access cover at bottom is removed to access bulb from underneath.
Old May 1, 2015 | 12:27 PM
Prospector's Avatar
Thank you, Redbull-1
jerrym
Sep 3, 2011 03:22 PM
piedmontguy
Mar 15, 2011 05:26 PM
ludo4841
Dec 2, 2009 12:32 PM
humblehyper
Mar 5, 2008 06:02 PM
Zer0Vtak
Dec 12, 2007 10:57 AM
