Frame Adjustment
Old Dec 18, 2013 | 07:43 PM
shadyinvasion04's Avatar
Default Frame Adjustment
Hello!! I'm a first time poster here on this forum... I have a 2007 Honda accord v6. My Honda has a rebuilt title. Due to the accident it was in... the frame has some damage and I know this because my alignment is always off. I took it to a tire shop and they were not able to align my tires like they were suppose to. Now my question is how much will it cost to take it to a body shop and repair the frame to the point where I can get my car to drive straight
Thank you!
Old Dec 18, 2013 | 08:32 PM
No one can answer this question definitively. It may be damaged beyond repair.
I would suggest finding several local reputable body shops and get estimates from each. I would speculate that costs will very quickly reach 4-digits.
It might be possible to install camber adjustable lower arms or upper arms that will allow camber to brought into alignment. Camber is usually the problem w/ noticeable pull left or right.
If you have alignment results, post them for possible insight to adjustment possibilities.
Old Dec 18, 2013 | 10:04 PM
kris_loehr's Avatar
I did wrecks in body shop for a while and getting the alignment right is pretty involved. Usually struts would bend first and after everything bent was replaced the subframe was the last resort if it showed no sign of damage. Some times loosening the bolts for the frame and moving it around brought it into specs. Are the shock towers damaged?
dengar169
Jan 7, 2008 04:20 PM
jmf8756
Jun 26, 2007 10:56 AM
rob3201
May 30, 2007 02:21 PM
RoKnAzn
May 21, 2007 06:29 PM
Mpwr
May 12, 2006 04:14 AM
