Freon coming out of a/c
It's in the 98-02 Honda Shop manual that you can purchase from automanualsource.com.
Procedure is straightforward, however sometimes details can get sticky (access):
1) Disconnect hi and low side connections on engine side of firewall. You need two open end wrenches; one to hold evap side fitting and one to turn tubing nut to loosen.
2) Remove glove box and glove box frame
3) Remove fasteners (2 bolts, 1 nut, 2 self-tapping screws) and electrical connector (1) to evap box. (need manual to find them all)
Strong chemical smell is not the refrigerant but the lubricant, PAG.
You can get orings from Honda or other online sources (ackits.com is one).
