Front Coil Spring question
Old Nov 4, 2007 | 11:14 PM
srlance24's Avatar
Default Front Coil Spring question
Hello,
Quick question regarding springs and tirewear. I noticed today on the front of my car that my driver's side is about 0.5-0.75" lower than my passenger side (measuring ground to center of fender). Will this cause uneven tire wear or other problems?
thanks
Old Nov 5, 2007 | 05:15 AM
Chiovnidca's Avatar
Default RE: Front Coil Spring question
Is the spring broken?
Old Nov 5, 2007 | 10:00 PM
srlance24's Avatar
nope, just a 0.5"-0.75" difference in height. rides fine too.
Old Nov 11, 2007 | 04:08 AM
Planefreak's Avatar
You haven't been driving like Chiovnidca have you?
When was the last time you rotated your tires?
Old Nov 11, 2007 | 06:45 AM
It could be a body problem, perhaps bumper is lower. Suggest downloading the 91 manual from DiY "Online Manuals" link. This has reference dimensions to allow a better assessment of problem. Spring damage or structural damage to suspension are about the only things that could lower the system.
Old Nov 11, 2007 | 07:49 AM
BlkCurrantKord's Avatar
Are you even lowered? Check the air pressure in the tires.
Old Nov 11, 2007 | 12:04 PM
srlance24's Avatar
Nope, all stock/OE parts on my car. tires are brand new, aligned and correct pressure. I'm just wondering if i could experience feather or cupped tire problems from the slight height difference (about .5"-.75"). and yes, i do plan to rotate these new tires every 6,000 miles
darkgreen18290
Apr 21, 2011 12:20 AM
kris_loehr
Sep 21, 2010 03:30 AM
Dhorn33
Jan 11, 2007 03:05 AM
el toro
Nov 1, 2006 09:20 PM
thunder_x
May 26, 2006 08:18 PM
