shock bushings or coil spring bushings?
Old May 25, 2006 | 08:59 PM
thunder_x's Avatar
Default shock bushings or coil spring bushings?
something in the front of my car squeeks whenever i pass a speed bump over 5 mph, and i was told that it was my bushings
i wanted to know which bushings to replace, shock bushings or coil spring bushings?
Old May 26, 2006 | 08:18 PM
AgentofDarkness's Avatar
Default RE: shock bushings or coil spring bushings?
What do you mean by spring bushing? You have a strut type suspension so the spring and the shock are together in one unit. It could also be control arm bushings b/c whenever you go over a bump the control arm will move up and down. If the bushing is bad, it will squeak.
Tek310
Jun 20, 2011 06:21 PM
srlance24
Nov 11, 2007 12:04 PM
kevinyu1115
Jun 3, 2007 12:16 AM
Dhorn33
Jan 11, 2007 03:05 AM
el toro
Nov 1, 2006 09:20 PM
