shock bushings or coil spring bushings?
something in the front of my car squeeks whenever i pass a speed bump over 5 mph, and i was told that it was my bushings
i wanted to know which bushings to replace, shock bushings or coil spring bushings?
What do you mean by spring bushing? You have a strut type suspension so the spring and the shock are together in one unit. It could also be control arm bushings b/c whenever you go over a bump the control arm will move up and down. If the bushing is bad, it will squeak.
