Front Passenger Power Door Lock Sticks
Old Apr 27, 2010 | 04:34 PM
hmr's Avatar
hmr
Default Front Passenger Power Door Lock Sticks
RE: my 2000 Accord EX-L sedan ( 4 cyl )
The following malfunction occurs intermittently during hot weather ( or when the car has been sitting out in the sun ). Never seems to happen at night or in cooler weather.
Front passenger door lock post will not go up or down or goes only partially up or down when activated by remote or the front door lock controls. I have to manually push the post down or pull it up. All other doors function normally.
Any advice on what is the cause and the fix would be greatly appreciated.
Thanks.
Old Apr 27, 2010 | 05:15 PM
hondadude's Avatar
Before you start taking off the door panel;
catch it in the act of binding and squirt some silicone spray around the **** and work it up and down.
You need to figure out if it is just a problem of the **** binding or if it is a motor malfunction.
HateThisHonda
Sep 19, 2013 09:45 AM
amituofo
Jun 15, 2013 08:32 AM
Doublel
Mar 11, 2013 07:57 AM
jkowtko
Aug 14, 2012 06:10 PM
Styler2K
Jul 31, 2006 03:11 AM
