Front Wheel Bearing Rusted in Place
Old Nov 17, 2007 | 05:51 PM
tsvore
Default Front Wheel Bearing Rusted in Place
The car is a 92 Accord EX. I am in the middle of replacing the passenger side front wheel bearing. The upright and hub are rusted to the suspencion upright. Can you recomend a technique to take this assenbly apart. I have it out of the car, but there is no way to get a puller on it. I'm thinking of buruning the race out tof the bearing to seperate the two. Any help would be appreciated.
Old Nov 18, 2007 | 01:28 PM
tsvore
Default RE: Front Wheel Bearing Rusted in Place
I ended up torching the bearing.
Old Nov 24, 2007 | 02:16 AM
honda671's Avatar
the only way to losen out your problem is to pound the problem with a hammer,use a hammer to losen out the rust just take extra care off where your pounding,as for your pully-all you need is a round end hammer and take off your axle nut from your shaft use the round end of the hammer and place it in the midle of your shaft where the nut was.use another hammer to hit the round hammer,your shaft should be able to slide off,no puller needed..check out this link hope it helps.
http://www.accordinglydone.com/forum...ad.php?t=14196
Old Dec 2, 2007 | 10:39 AM
tsvore
Thanks Honda671.
LS-300
Jun 14, 2014 08:22 AM
joenintiesc
Apr 14, 2013 07:29 AM
ScottSoSlick
Mar 18, 2009 03:28 PM
oma93
Feb 6, 2008 12:43 AM
JDMSR20
Dec 20, 2006 01:33 PM
