front windows have a hard time closing?
Old Jun 21, 2011 | 05:07 PM
phatboyslim2012's Avatar
Default front windows have a hard time closing?
so my 97 lx has a window issue
the power windows have an issue going up, it may be bad motors but they pop off track and get stuck, if i pop em back in they go up fine. i was looking at the helms manual, and it looks like there should be a window guide track at the top end of the windows, am i correct. how do i go by fixing this issue?
Old Jun 21, 2011 | 05:34 PM
I would probably do two things.
1. Lubricate the run channel inside of the door with silicone paste (not spray). You can use the white grease for caliper pins that you get in the packets at the parts store.
2. Adjust the glass. If you have the shop manual for the 94, page 20-14 starts the procedure. It is pretty simple to do.
Old Jun 21, 2011 | 06:08 PM
i have the 94-97 helms manual ill check that now, i have silicone grease ill lube the run channels, i took a look at the windows and theres no trace of a guide pin on either window, does the pin not exist on the 97?
Old Jun 21, 2011 | 06:17 PM
Take a look in the shop manual, because it shows a guide pin.
You may not be able to see the pin, because I think it is hidden in the run channel.
Old Jun 21, 2011 | 06:29 PM
i have the manual open now, the driver side is a honda window, passenger is replacement. i pulled out the pass. window enough to see the edge of the window if i am correct the pin goes through the window, there insnt even a whole for it, also i pulled out the weather strip on the driver side, and there is no guide rail in the door for the pin. ill take pics and post them for you
Old Jun 21, 2011 | 06:41 PM
Old Jun 21, 2011 | 08:38 PM
Maybe there is a guide pin for the coupe. I would still do the glass adjustment. You want to loosen the bolts holding the glass. You want to pus the window up and towards the back of the car to align it.
Old Jun 21, 2011 | 08:58 PM
yea, ill align the windows in the morning, the passenger side is worse it will turn forward enough to get stuck half way up, ill have to roll down a tiny bit push into place and then finish rolling up, the back windows aer perfectly fine
anupm12
Jan 6, 2016 07:47 PM
92lx
Jul 22, 2012 08:32 AM
graymike
Oct 17, 2011 06:05 PM
juststeve
Feb 26, 2011 07:52 PM
19Accord97
Mar 1, 2009 12:19 AM
