Frozen Locks
Old Jan 3, 2014 | 08:16 AM
spezi22's Avatar
Default Frozen Locks
Good morning -- after a snowstorm and freezing temperatures, I am unable to open my 2007 Honda Accord door locks with the FOB key. (The trunk does open.) When I tried the key manually, the drivers' door initially opened a quarter inch, but not completely. I suspect the anti-theft system may be the culprit, as I scraped all around the door to break the ice. Unfortunately, something happened in the interim and I am no longer able to manually open this door even a little.
As you can probably tell, I'm not very car savvy and would love any advice. 1) Is there a short term fix so that I can go to work today? 2) Is this a problem that will solve itself when temperatures warm up, or do I need to bring it into the shop for more serious maintenance?
Thanks very much for any advice!
Old Jan 3, 2014 | 08:40 AM
See youtube videos on "winterize your car" by briansmobile1. He discusses strategies for frozen door locks in one of these, but I don't remember which one
Chemicals (alcohol?) are used to melt ice and lubricants are added to improve lock movement is what I remember.
Old Jan 3, 2014 | 11:18 AM
Other than the driver's door, does the other door(s) open with the remote? Is your car a coupe or sedan?
If only the driver's door doesn't open, the issue with the driver's door sounds like a latch issue. Wait and see if the door opens when the temps. warms up a bit.
Old Jan 3, 2014 | 09:12 PM
kris_loehr's Avatar
Can you crawl through the trunk start the car up and turn the heat on?
eddie2514
Feb 27, 2013 05:22 AM
nickmg555
Oct 12, 2012 04:07 AM
de_shadows
Feb 2, 2012 06:57 AM
Tiana 99 accord coupe
Aug 12, 2011 02:36 PM
djstrickland
Sep 16, 2010 09:39 AM
