fuel door release inoperative
Old Jun 28, 2008 | 07:36 PM
dacecil's Avatar
Default fuel door release inoperative
How do I get the fuel door open on a 92 Accord if the inside lever doesn't work? It's not locked as the trunk release does work. I looked in the trunk for a cable but didn't find anyting. Help, I'm almost out of gas.
Thanks,
Dale
Old Jun 28, 2008 | 07:59 PM
hondadude's Avatar
Default RE: fuel door release inoperative
Go into the trunk on the drivers side and peel back the liner; there are a couple button retainers that need removed.
Then you should be able to see the cable end going to the fuel door area, it has squeeze clips. You can then remove that end of the cable from the holder to let the fuel door open.
Replacement of the cable is a job I hated to do, rear seat has to come out, scuff plates from the doors, peel back carpet..etc.
Old Jun 29, 2008 | 08:25 AM
You could rig a release in the trunk. Some BMW's have this feature built-in.
smiyares
May 24, 2017 07:39 PM
Ledzeppelin77
Jul 19, 2015 06:09 AM
madsteez
Oct 28, 2008 09:27 PM
JoeAsheville
Aug 26, 2007 11:51 AM
JoeAsheville
Aug 26, 2007 11:13 AM
