Fuel door wont open '97
Old Apr 13, 2011 | 08:43 PM
nickmg555's Avatar
Default Fuel door wont open '97
To add to my current other problems. The fuel door does not open. When i pull the fuel door release i hear the cable and it is pulling in the latch but it wont spring open. Is there a spring i can purchase or replace? do i need a new fuel door? I was considering taking a pen spring and stretching it slightly and super gluing it to the inside of the fuel door. I have been able to get it open when i jam a screwdriver in the fuel door then pull the release.
Old Apr 13, 2011 | 09:36 PM
Check whether the latch-tab is bent so it sticks even when the pin is pulled out.
The spring is probably something that looks like a little metal tab right at the hinge. Try bending it a bit? I bet a pen-spring will be way too weak.
Old Apr 13, 2011 | 09:41 PM
nickmg555's Avatar
I was planning on multiple stretched pen springs glued along the edges but id much rather just see if i can find the tab and bend it back. I will post my finding tomorrow around 1 pm e.s.t. when im free.
Old Apr 14, 2011 | 04:06 PM
nickmg555's Avatar
I grabbed some strips of 40 thousandth inch aluminum from the scrap bin in the hangar if i can figure out exactly where the old metal tab was i can prob just cute the strip and replace it.
MrGmo
Sep 28, 2007 01:40 AM
lakehopper
Aug 15, 2007 11:28 PM
maro
Mar 26, 2007 07:08 PM
smoothoperator
Jan 30, 2007 09:00 PM
