fuel filter
Old Nov 4, 2011 | 05:45 AM
rwyatt80's Avatar
Default fuel filter
Hello!!
I was looking around the site for possible pics and directions on how to change out a fuel filter on a 96 accord lx with no success.
Does anyone know where I can find this information?
Any help is greatly appreciated!!!
Old Nov 4, 2011 | 09:40 AM
It located in the DIY section. There are more DIY threads there, you just have to change it to show from the "beginning" to see them all (see attached picture). Sometimes when searching, trying different words.
Anyways, here is the thread, the pictures are in a link in this thread:
https://www.hondaaccordforum.com/for...-90-97-a-3045/
Old Nov 4, 2011 | 12:18 PM
Posters are always wanting to change the fuel filter, possibly because it was much easier on earlier Accords. On this vintage it is a real challenge to access and replace.
Honda does not specify a replacement interval. If fuel pressure is OK (starts good and runs OK), I would recommend leaving alone. If you're having problems a fuel pressure check can save a difficult job w/ potential to cause added problems (damage to tubing connections).
Old Nov 4, 2011 | 06:00 PM
rwyatt80's Avatar
the fuel filter has only been changed once, since the car rolled off the assembly line in 1996. The manual states every 30,000 mi or 24 months. The reason I considered changing it is because of how much I travel and the conditions I travel in. But if it is one of those things where I dont need to follow the manual, trust me, I dont have any problem backing away from this project...lol..
Old Nov 4, 2011 | 06:13 PM
Sorry my mistake, you are correct about the 30K change interval. However the advice still holds. There is a primary screen on the fuel pump inlet which prevents most debris from getting to the filter.
When I removed my fuel tank for fuel pump replacement, the screen was clean and so was the tank. I concluded that debris is unlikely. This is backed up by no cases of fuel filter blockage. It must happen, but I don't remember ever seeing one posted.
Old Nov 5, 2011 | 07:32 AM
moey's Avatar
Ive never changed mine, I have a 96 accord with 190k in the rust belt
Im inclined to leave fuel systems alone unless they look they are going to imminently fail. I just hate messing with the fuel, no matter what I do it never goes to plan.
rockhoundrob
Apr 11, 2014 11:41 AM
Special_K
Aug 12, 2011 04:16 PM
bjr001
Mar 5, 2010 07:31 PM
mojorison_75
Dec 4, 2005 06:40 PM
Buckeye
May 8, 2005 12:41 AM
