Fuel gauge question
Old Oct 13, 2013 | 09:44 AM
sschnei's Avatar
Default Fuel gauge question
Back with a question on the fuel gauge. It works... sometimes. Seems to have a mind of it's own. When it's not working it indicates 'Full'.
I figured it was a fuel sender problem and replaced it. Problem still not resolved. I verified continuity from ground terminal to the chassis ground...looks good. Verified DC volts at connector with ignition at on position.
I'm at a loss... any thoughts?
Old Oct 13, 2013 | 03:11 PM
If the problem did not go away with the new sending unit, then the fuel gauge in the cluster is the culprit.
You can take apart the cluster and check for bad solder joints and/or corrosion where the gauge has connections to the cluster circuit board.
pirulino23
Nov 10, 2010 06:18 PM
woody
Sep 15, 2010 09:20 AM
darryltravis
Apr 25, 2006 01:26 AM
Thekidd
Aug 21, 2005 12:51 AM
rogersah
Mar 22, 2005 02:56 AM
