Fuel level sending unit???
Old Jun 28, 2006 | 03:46 PM
Triblade's Avatar
Default Fuel level sending unit???
Hello my fuel gauge is not very accurate. When i brake or accelerate the fuel gauge moves for example from 3/4 of a tank to 1/2 and when the light indicates empty there still remains another 15 -20 L in my tank. I am about to change the fuel level sending unit but before i do I would lilke to know if there are any other possibilities??? thank you
Old Jun 28, 2006 | 04:04 PM
sir_nasty's Avatar
Default RE: Fuel level sending unit???
I'm not exactly sure how to test this but you may want to make sure that it's not either a short somewhere or the gauge itself..
Old Jun 28, 2006 | 08:38 PM
Chiovnidca's Avatar
ORIGINAL: Triblade
The light doesn't tell you when it's empty, you can figure that out for yourself when it dies. It's a low fuel light.
Old Jun 28, 2006 | 11:44 PM
marbro's Avatar
With my 98 accord at E theres still about 5 to 6 gallons left, and then the light kicks on 3 to 4 left, i have a 17gallon tank
Old Jun 29, 2006 | 04:39 AM
deserthonda's Avatar
OK HERE WE GO AGAIN...........NO YEAR NOR MODEL...........Input year and model on your signature , it will make it easier for members to help you with the correct reply the first time ..
since i do not know year and model I CANNOT give you details on how to remove the sending unit , or test the wiring etc etc...
However i can tell you how to test the sending unit once you have it out of the car ,,
you need a multimeter and chk resistance on the 2 wiring on the left of the raised snap in on the sending unit.. you need to move the plunger as if the tank were empty ( all the way down) 1/2 way,, and full ( all the way up)
resistance should be as follow ..
empty 105-110 ohms
1/2 25.5-39.5 ohms
full 3-5 ohms
if out of specs replace sending unit .. these are for a 96 accord but they should be relatively close to other cars
Old Jun 29, 2006 | 11:10 AM
YeuEmMaiMai's Avatar
Every single car that I have had as done this at some point in time and every single time the result to fix was replace fuel sending unit. On a lot of cars it is intergrated into the fuel pump but I believe that it is separte on these cars.
Old Jun 29, 2006 | 11:54 AM
it is separate from the fuel pump......
Botones95
Oct 9, 2008 04:49 PM
razcob
Dec 30, 2007 10:44 AM
xaznxeclipsex
Sep 28, 2007 05:07 PM
IWL BCNU
Sep 13, 2007 08:40 PM
IWL BCNU
Sep 13, 2007 05:35 AM
