fuel mileage dropped suddenly
Old Mar 17, 2007 | 12:12 AM
david314's Avatar
Default fuel mileage dropped suddenly
Hi,
I have a '99 Accord 2.3 liter 5 speed, 120k. Until last fall, I was getting about 33mpg in driving that was about 4/5ths country roads, 45mph with few stops, and in-town for the rest. Suddenly, like within a period of a couple of weeks to a month, last october, mileage dropped to around 29.
I keep tire pressure at around 35. Air cleaner was less than 6 months old. I don't think there are alignment issues--tire wear is even. Car was tuned (new plugs, wires, I think injectors were cleaned, I forget what else) right after the drop, may have kicked mileage up half a mpg to 1 mpg. Fuel filter may be original (I got the car at 67k) but Honda dealer tells me it's good for 150-175k. The guy who tuned the car suggested ethanol, which had just started being added to the gasoline for the winter (for the first time here) might be the culprit, but Mass has only 5% etoh, so my estimate is that might account for 1.5mpg (roughly 5% of my gas mileage) drop but no more.
Any ideas?
Thanks,
David
Old Mar 17, 2007 | 12:16 AM
deserthonda's Avatar
Default RE: fuel mileage dropped suddenly
the change in weather might have some affect on gas mileage drop ..colder weather, engine runs more on fast idle when warming up,,,, winter fuel ?
Old Mar 17, 2007 | 01:36 AM
smaglik's Avatar
Winter fuel is what I was thinking too, but if he bought it at 67k, he should have seen a winter before. The fuel filter seems questionable. 150-175k? How do you know when its bad? Bad fuel economy?
Old Mar 17, 2007 | 02:07 AM
david314's Avatar
It wasn't the cold weather. I had very little drop the previous winter, maybe a mpg at most.
Old Mar 17, 2007 | 12:00 PM
If you haven't replaced ignition parts recently, I would start w/ new spark plugs. A good set of iridium plugs can make a world of difference. Also primary O2 sensor (forward of catalytic converter) can gradually reduce performance w/o setting a code. I have an Acura 2.5TL that I thought was running pretty fair. Under a Acura recall program, the wires, plugs, distributor cap, rotor, and O2 sensor were replaced. I was amazed at difference in idle smoothness and fuel efficiency increased modestly 5-10% perhaps.
Air intake filter should be replaced. Make sure PCV and PCV hose are clean and working.
Check fuel pressure regulator vacuum reference line for smell of gasoline. If the diaphragm fails, gasoline is pulled into the engine through the vacuum reference line and fuel efficiency suffers substantially. New regulator is necessary if you smell fuel.
JHeim81
May 22, 2011 09:41 PM
pderdadon
Sep 7, 2010 07:24 PM
raygun267
Mar 31, 2010 09:02 AM
edohopar
May 23, 2009 04:29 AM
g vice
Mar 7, 2007 10:58 AM
