fuel propblems
Old May 2, 2006 | 06:12 PM
Tarsis's Avatar
Default fuel propblems
my 91 accord has a problem getting fuel it willo start once in a while and if im lucky 2 times in a row i checked to see if i was getting fule to the injetors but im not when the car wont start, i trhink the fuel pump is going out or a wire to the pump is bad or the lfule pump is getting cloged. can anyone help? i did change the fuel filter
Old May 2, 2006 | 06:44 PM
AgentofDarkness's Avatar
Default RE: fuel propblems
The first question you want to ask is if your problem is fuel or ignition (these are the 2 most common problems if you car won't start). If you are sure that your problem is fuel, then your best bet is gonna be to get a fuel pressure guage. This is the best way to check if your fuel system is working properly. If you have fuel pressure but your car still doesn't start, there is a problem with the fuel injection. If you don't have any fuel pressure, either the fuel pump isn't turning on, the fuel pump isn't pumping fuel, or there is a clog in the fuel system. A quick test to see if your fuel pump is getting power is to put a meter on the power wire to the fuel pump and ground and see if there is voltage. If there is voltage, then you are getting power to the fuel pump and it should be pumping fuel.
Old May 15, 2006 | 11:47 PM
Tarsis's Avatar
its a main relay and now i have a major gas leak
Old May 16, 2006 | 12:37 AM
mbo1985's Avatar
How did you get the fuel leak??
Old May 16, 2006 | 03:58 AM
deserthonda's Avatar
ORIGINAL: Tarsis
ok.. what happened ??
Westjoe64
Oct 15, 2012 12:11 PM
BigOBob
Jan 1, 2012 02:47 PM
woody
Sep 15, 2010 09:20 AM
fortyfootelf
Jan 22, 2010 07:15 PM
kissbally78
Jan 18, 2009 07:14 PM
