Fuel pump delays when I turn on the ignition??
Old Feb 19, 2012 | 07:25 AM
I would start with testing the "inputs" to the main relay......lack of or poor ground connection, ect.....
Old Feb 19, 2012 | 09:36 AM
josh22x's Avatar
Are you referring to something like this: NO START HONDA PGM-FI MAIN RELAY TEST - YouTube ?
Thanks!
Old Feb 19, 2012 | 10:28 AM
Yes, something like that but a little more involved....Have you downloaded the manual form the Common DIY Threads sticky at the top?
Old Feb 20, 2012 | 11:51 AM
josh22x's Avatar
No I have not. I did not see it in the list?
Old Feb 20, 2012 | 06:01 PM
Two things, please add your car info to your signature line.
Second, for this the 94 manual will work fine.
It will go something like this.....pic of the wire side is on the manual
Pin 3-blk- ground with key off
Pin 7-WHT/GRN- 12v with key off
Pin 5- RED/WHT- 12v key on
Pin 2- BLU/RED- 12v key on
The rest get into the signals from and two the ECU and the other pins on the main relay.
Old May 19, 2012 | 12:54 PM
hh7304@sbcglobal.net's Avatar
Default Fuel pump delay
Josh...did u ever figure out the problem on ur fuel pump delay....my brother has the same car and is experiencing the exact same problem....usually after sitting in sun etc. Really weird....
Old May 19, 2012 | 01:01 PM
  #17
crispin's Avatar
Josh has not been on this board for 3 months.
Sadly new most members join to solve a problem, once the problem is solved they do not come back or even let us know that the problem was solved.
Old May 20, 2012 | 06:53 AM
  #18
There are some testing procedures listed in this thread. Based upon your description, I would focus on the main relay.
Old May 20, 2012 | 10:11 AM
  #19
Arrow Fuel pump delay
Thanks guys for responding.....we have replaced the fuel pump and the relay with new quality parts....i guess its possible that the new relay is defective...we still have the old one so we will re-solder the connections on it and reinstall it. I will definitely post the results.
Old May 20, 2012 | 11:02 AM
  #20
Again, testing is going to be needed. Replacing on a guess gets expensive.
First question, are you sure it is a lack of fuel?
