fuel pump location
Old Jun 18, 2007 | 04:40 PM
grimace007
Default fuel pump location
where is the fuel pump on a 1991 accord?
im havin trouble with a friends car, he brought it to me with a bad starter and alt, but it still wont start
it acts like it wants to but wont
i removed the maine fuel line from the injector rail and turned the motor over nothing came out not a drop!
i removed the back seat and took that sill cover off then removed what i hoped was the pump but it was just the gauge sending unit.
WHERE oh WHERE? can it be? haha
does it sound like im on the right track here?
the motor will run if i spray carb cleaner into the intake hose so i assume it has plenty of spark
anyhelp is appreciatec
Old Jun 18, 2007 | 05:33 PM
Default RE: fuel pump location
Download the shop manual from the ONLINE MANUALS link in the DIY section. Its the hondahookup link. The component location index for the fuel system is in chapter 6 in the beginning.
Before you go to change the fuel pump, make sure there is 12V on the yellow wire at the connector in the trunk. You have to do this within the first two seconds of turning on the key, so you might need and assistant. If you have power then the pump is likely bad.
You will have to drop the gas tank to change the fuel pump.
Old Jun 18, 2007 | 06:57 PM
deserthonda's Avatar
Do not rule out the possibilities of a bad main relay , bad fuse ?? chk the easy stuff first
DIAGNOSE before you start replacing parts,
Old Jun 18, 2007 | 08:59 PM
grimace007
i had gone thuogh the fuses, and everything thing else, believe me i know and i ended up pulling the fuel tank, and pump, tested the pump and it was bad. oh well. now thats a starter, alt and fuel pump lol
this car will be in good hsape as long as no one fries the electrical again
Old Jun 18, 2007 | 09:22 PM
grimace007
just a little background im a self taught ( shadetree ) mechanic but have been building high performance cars and restoring classics for the past 7 years this is just a side job im not too familiar with hondas.
thanks again for all the help guys!
ill have the new fuel pump in the mornin
mrfloyd227
Jul 17, 2015 06:13 PM
Hidden lights
Mar 3, 2015 06:39 PM
Fubz
Dec 27, 2012 10:26 AM
Westjoe64
Oct 15, 2012 12:11 PM
kissbally78
Jan 18, 2009 07:14 PM
