fuel rail bolt 98 accord
Old Feb 1, 2011 | 11:54 PM
honDUHchick's Avatar
Default fuel rail bolt 98 accord
do they have a special name and where the heck can i ge 2 new ones? theyre the 2 bolts that bolt the rail to the motor to hold in the injectors
Old Feb 2, 2011 | 12:32 AM
I'm guessing the part you need is #20 in the pic below?
You can order from the dealership. Some dealerships will ship the parts to you. You would have to call. There are online that carry dealership parts like hondapartsnow.com or majestic honda. It will take longer to get what you need.
The other option is getting them from a wrecked accord at a local junkyard, if you need them quickly.
Old Feb 2, 2011 | 01:35 PM
ok thank you! thats the one i need and so far its a pain in my arsenal to find one. ill be going to a junkyard today, they think thy have what i need. if not ill call the dealer. ill keep u posted! this should fix my problems, bc im getting new injectors too.
Old Feb 2, 2011 | 01:49 PM
The OEM part number for #20 is: 90027-P0A-003 Genuine Honda BOLT A, FUEL PIPE
Listed below are all of the honda vehicles that use that same fuel rail bolt. You should be able to find 2 good fuel rail bolts from these vehicles.
ACCORD 2D 94-97
ACCORD 2D 98-02
ACCORD 4D '02
ACCORD 4D 94-97 E2/V-6 E2
ACCORD 4D 98-01
ACCORD WAGON 94-97
CIVIC 2D 96-00
CIVIC 3D 96-00
CIVIC 4D 96-97(US) 96-00(EXP)
CIVIC 4D 98-00
DEL SOL 93-97
ODYSSEY 95-98
Old Feb 2, 2011 | 02:02 PM
o wow youi have no idea how helpful THAT was! thank you oh so much!
Old Feb 2, 2011 | 02:16 PM
No problem. Its easy to find that info.
Go to you favorite OEM parts site (I use hondapartsnow.com).
Enter your vehicle info.
Find your part (your bolt was under engine, intake manifold).
Click on the part number.
On the bottom of the new page that opens up, has links to all of the generations of Hondas that share that same part number.
I would click on each link. For example the coil for my old 95 accord EX had ACCORD 4D 94-97 E2/V-6 E2 listed. You might assume that all 4-door 94-97 accords used this part, but that is not the case. When I clicked on it, it only showed EX models.
I would take the original part with you, so you can compare the junkyard part to your 98's part.
BigOBob
Jan 1, 2012 02:47 PM
fortyfootelf
Jan 22, 2010 07:15 PM
DA KID RYU
Nov 10, 2009 09:23 AM
FarRockAccord
Jul 10, 2008 11:17 PM
steviebix
Nov 20, 2007 04:04 PM
