Fuse or Light??
Old Aug 16, 2011 | 10:36 AM
DaveHMD's Avatar
Default Fuse or Light??
Accord 2004 LX no longer signals when ignition key inserted and driver door open or when headlights left on after ignition off. Also light near the bottom of the driver's door is out. Is the problem a fuse or just the door light in series with the other problems? If a fuse, I can't find it listed in the manual.
Old Aug 16, 2011 | 07:04 PM
cb7sk8rdude's Avatar
why are you signalling when the door is open?
Old Aug 16, 2011 | 07:50 PM
Stylee81's Avatar
i think hes refering to the audible "chimes" the car makes when the door is open or when you leave your lights on
Old Aug 16, 2011 | 10:06 PM
DaveHMD's Avatar
Stylee81 is correct. No chimes. No light. No ideas how to fix.
Old Aug 16, 2011 | 10:54 PM
The door light may be a separate issue. If you have a volt meter, you can see if you have 12V across the pins for that bulb connector. You can look to see if the filament is burned out as well.
The chime problem may be more of a challenge to figure out. I would check the #7 and #21 fuses in the fuse box under the driver's dash. See attached pic.
Old Aug 17, 2011 | 08:49 AM
DaveHMD's Avatar
Thanks PAhonda - According (no pun intended) to my owner's manual, fuse 7 is back-up lights. I have no problem with them. Not sure what #21 (IG Meter) means, so will check that one.
Old Aug 17, 2011 | 02:09 PM
Check both of the fuses. I wasn't guessing at the fuses. There was a wiring diagram showing those two fuses protecting wires indicators.
tvandentop
Sep 17, 2011 06:42 AM
desfam5
Apr 19, 2011 12:08 AM
foxylady23
May 18, 2009 12:27 PM
piffmiester2006
Jun 4, 2007 10:49 AM
kaiotes
Dec 14, 2006 08:23 PM
