Gas Cap Hiss 94 LX
Old May 29, 2013 | 10:49 AM
skyfire322's Avatar
Default Gas Cap Hiss 94 LX
I've noticed that whenever I open up the gas cap to put fuel in the tank, it makes a hissing noise. Once the gas cap is off, there's sometimes a small blast of fuel odor when it's completely off. I've read a few different forums and have seen different answers... Some say it's normal, others say it's not.
There is an exhaust leak coming from somewhere, and whenever I turn on my A/C or heat, there is a faint gasoline smell. The other two cars I have owned have never done this, even when it got really hot out. When I do put it back on, I make sure it's on tight enough too.... I tighten it to three or four clicks.
Is this usually a normal thing? There aren't any CEL codes or anything if that helps.
Old May 29, 2013 | 10:55 AM
kayweb's Avatar
Mine does the same thing, but it's because I don't have a charcoal canister. It's the black cylinder under the cruise control unit (if you have one), mounted on the firewall. Check the lines leading to and from it, maybe?
denierlexiese
Aug 7, 2015 12:08 PM
MessAround
Aug 23, 2011 01:36 PM
ikethegreat
Nov 19, 2007 03:07 PM
bginvestor1
Nov 14, 2007 10:07 PM
mlydellj
Jul 6, 2006 10:37 AM
