Mystery hiss...
Old Aug 22, 2011 | 05:13 PM
MessAround's Avatar
Almost A Senior Member
Default Mystery hiss...
Anyone know if a hiss is normaly near the PS pump on a 1993 Accord? If not, does anyone know what it my be symptomatic of? I know for sure that it's in that region. I placed on ear over many areas but it's definitely coming from the PS pump region.
Could it just be an old belt on the way out?
I also noticed that udner the PS pump where the compressor belt is, the compressor belt appears to be chaffing on something between it and the lower timing cover. It may even be the timing cover itself. It appears melted. That side of the belt (left) is also shiny glazed.
Old Aug 22, 2011 | 05:44 PM
Peli's Avatar
Is it a constant hiss? When my PS pump goes on it makes more of a loud farting sound rather than a hiss and it only does it for about a second or so.
Old Aug 22, 2011 | 07:28 PM
MessAround's Avatar
Yeah it sounds like a sustained hiss "ssssssssssssssssssssssss" that doesn't go away. It's definitely coming from the PS pump region because I put one ear towards the regions and move around until I can hear it. Then I put my ear right above the PS pump facing it to the floor and I can hear it louder. I moved to the timing cover where the fuel rail is and it disappeared, moved back to PS pump and there it is again.
I think it's the compressor belt chaffing on that thing between the belt and lower cover or it's the lower cover itself. There's some kind of deformed thing between the two, it almost looks like some piece of twisted debris, a leaf or possibly melted plastic. I think the lower cover came loose and rubbed on the compressor belt since the side of the compressor belt facing the debris is shiny and glazed (only on the top not ribbed side of the belt). If this were the case what are my options? Possibly sand the lower timing cover down or replace it?
Old Aug 23, 2011 | 12:13 AM
Was it the fliud in the pump that was hissing?
Old Aug 23, 2011 | 10:21 AM
Is your cruise-control unit anywhere nearby? How about a vacuum leak in that thing?
Old Aug 23, 2011 | 10:29 AM
tradosaurus's Avatar
Do you have a snake in your engine compartment?
Old Aug 23, 2011 | 01:36 PM
Roader's Avatar
A two or three foot piece of hose - garden hose will do fine - is good for finding the source of mysterious noises.
denierlexiese
Aug 7, 2015 12:08 PM
skyfire322
May 29, 2013 10:55 AM
ikethegreat
Nov 19, 2007 03:07 PM
bginvestor1
Nov 14, 2007 10:07 PM
avrillu
May 17, 2006 09:14 PM
