loosing water
Old Aug 21, 2011 | 01:48 PM
Miamijuan's Avatar
Default loosing water
Hi all i have a 1996 accord vtec 2.2lt. The problem i have is that is loosing water and i cant find a leak. Also the heat seems to be comming in thru the cabin vents. I replace water every few days. The car doesnt overhaet unless i forget Everytime i stop somewhere i come back to my car i see condensation on the windshield. My defroster also doesnt work i dont know if this is related. I recently changed the thermostat. Thanks for your help.
Old Aug 21, 2011 | 02:24 PM
piggylover1985's Avatar
I'm not sure what are you talking about loosing water and you have to replace water every few days ? Is it antifreeze or windshield washer fluid ? Can you be a little more clear please.
Old Aug 21, 2011 | 02:55 PM
bigpat's Avatar
Almost A Senior Member
If you have condensation on the inside of the windshield, and your defroster isn't working, I suspect you have a heater core leak. Pull up the carpet and see if the floorpans are wet behind the glove box and the pedals...If so, that is why.
Old Aug 22, 2011 | 10:03 PM
Miamijuan's Avatar
I have to add water to the radiator
Old Aug 22, 2011 | 10:58 PM
Follow bigpat's suggestion. Sounds like a problem with the heater core. Does the inside of the car smell like coolant?
Old Aug 23, 2011 | 11:47 AM
Miamijuan's Avatar
I felt the carpet and i dont think its wet. Sometimes when im driving i smell antifreeze. Hoe much does a heater core cost and is it an easy fix?
Old Aug 23, 2011 | 12:49 PM
The Honda one is expensive. The aftermarket probably range from $50 to $150. You will have to shop around.
I think that you have to remove a lot of stuff on the dash to get to the heater core. I would suggest going to the common diy thread on top of the gen tech help forum. There is a link to online shop manuals. The honda-tech link has a 94 shop manual that will detail the steps to do the repair.
Old Aug 23, 2011 | 03:36 PM
bigpat's Avatar
The heater core is small...not much bigger than a paperback book. It acts as a radiator for the interior heater and defroster. I did one on my El Camino years ago, but that was a relatively simple and easily accessable job to complete. The Honda will be quite confined and access may require removal of the glovebox interior, radio and vent contols, or possibly the dashboard. Look for the tech link in the manual to see what you are facing. Before you dive in to the repair, get a qualified shop to assess the situation to verify that it is infact the heater core leaking.
dornbla9
May 18, 2012 09:53 PM
bustum
Apr 11, 2012 02:10 PM
1accord1996
Apr 7, 2011 12:36 PM
NJ007
Feb 6, 2011 01:14 AM
Mikkos
Feb 26, 2010 03:19 PM
