Gas door wont open lever wont budge
Old Sep 27, 2007 | 07:46 PM
MrGmo's Avatar
Default Gas door wont open lever wont budge
so today i pull up to put gas and i push the lever down to open the gas door thing and it just wouldnt budge. is there a way to fix this... i treid to pry the door open but felt really bad coz it started to scratch the paint
anyone please helpppp.... thank you
Old Sep 28, 2007 | 01:40 AM
Default RE: Gas door wont open lever wont budge
Most likely the cable is stuck. I'm not sure how the setup is on an 01, but I can give you a description on the 95.
The trunk/gas cap is on the floorboard near the door. The plastic cover is held on by a screw. You will have to pry up a tab to get to that screw. Once the cover is off, there should be a cable coming from the rear of the car into that assembly. I would first try to spray wd-40 on it to try to unbind it. If that doesn't work, try grabbing the end of that cable (it is a metal cylinder that tees off at the end) with a pair of pliers and pull it towards the front of the car. I wouldn't grab the cable part, because you might fray it.
kegwad
Jun 22, 2009 09:20 AM
wietgr
Nov 22, 2007 10:50 AM
zpak
Jan 10, 2006 12:09 AM
