Innova OBD2 scanner works on 95 Accord?
Old Sep 27, 2007 | 04:48 PM
crvone's Avatar
Default Innova OBD2 scanner works on 95 Accord?
Hi,
Does 95 Accord have OBD or OBDII ? Would an Innova OBBD2 read OBD system's codes (backward compatible)? I got both SRS and ABS light on my car and can get an OBD2 reader, but want to make sure it's going to work before shelling out money... thanks in advance.
Old Sep 27, 2007 | 04:56 PM
00AccordLX5spd's Avatar
Registered User
Default RE: Innova OBD2 scanner works on 95 Accord?
On a 1995 V6, yes - OBDII. On a 1995 4cyl, no...OBDI
Old Sep 27, 2007 | 10:53 PM
19Accord97
Most car places will check your check engine light for free. Such as AutoZone and Advance Auto.
Old Sep 27, 2007 | 11:42 PM
deserthonda's Avatar
you can jump the sc connector under the glove box and read the codes ,, jump the one with 2 wires and NOT the one with 3 wires ,,then just read the codes on the instrument cluster with key on,
Old Sep 28, 2007 | 10:55 AM
Registered User
ORIGINAL: 19Accord97
That is true, IF they have an OBDI scanner for his. The AZ around here only has an OBDII scanner. Call your local parts stores and ask them if they can read the codes for you. Be sure to tell them your car's computer is OBDI.
Or you could always jumper the connector yourself as dh suggested.
Bill_ss54
Sep 18, 2014 05:08 PM
SevenFour
May 22, 2012 11:48 AM
supercd5accord
Aug 9, 2011 12:33 AM
ruaphuNZ
Feb 13, 2011 09:48 AM
Bacondoggy
Oct 5, 2009 10:27 PM
