Gas Mileage?
Old Sep 22, 2006 | 04:00 PM
WhyNotFab's Avatar
Default Gas Mileage?
How many gallons of gas should my 1996 Accord LX hold?
I know it'd never be complely empty.. and I want to fill it up, then find out my gas mileage.
Or would it be smarter to get it on E, put a certain amount of gallons and divide miles?
Post tips on calculating.. Thanks!
Old Sep 22, 2006 | 04:02 PM
sir_nasty's Avatar
Default RE: Gas Mileage?
the easiest way to do it is to fill your gas tank as full as you can, reset your trip odometer, run for at least half a tank, then fill up the gas tank as full as you can again and record how many gallons it took, then divide the miles on your odometer by the gallons used and it should give you the most exact number you're going to get, fill up at the same location/same pump both times to get the most accurate reading
jkp
Aug 26, 2017 11:11 PM
sleep depervation
May 8, 2006 10:41 AM
BigPete
Apr 18, 2006 07:04 PM
mpanelli
Apr 12, 2006 04:28 PM
accordtypeexl
Feb 13, 2006 03:20 PM
