Gas smell in cab when I put gas in tank
Old Nov 22, 2010 | 04:48 PM
bjr001's Avatar
Default Gas smell in cab when I put gas in tank
Hi,
After I gas up my car usually it is near empty, I smell an odor of gas in the car. This odor normally lasts for a few minutes then goes away. I normally roll down the windows during this time. I’m careful not to spill any gas on me nor step in any gas that someone occasionally spills on the pavement. What could be causing this gas smell after I start the car.?
Thanks
Old Nov 22, 2010 | 04:56 PM
Do you gas up with your vehicle running...?
Old Nov 22, 2010 | 05:27 PM
... or do you try to "top off" the tank by clicking the nozzle again & again? Either one of those can confuse the car's EVAP canister system.
Old Nov 23, 2010 | 07:29 AM
bjr001's Avatar
Hi guys,
No, the car is off and the keys are out of the ignition when I gas up. I don't top off, ever. Normally when I put gas in the car the vehicle is near empty and I normally add a third to half a tank. I have filled it up a few times but never top-off the tank. The smell comes after I finish gassing replace the gas cap and then start the car.
Thanks
Old Nov 23, 2010 | 03:55 PM
Check-engine light on? If so, get the code & tell us.
Look underneath the left-side of the car. Five tubes running along under the floorpan. Three of these are fuel lines - are they wet? I had some corrosion (95 Integra) made those lines kinda spongy. They didn't leak big drops, there were no puddles of fuel on the garage floor. But the lines just leaked about as fast as the fuel evaporated so they were always just a bit wet. And smelly.
Old Nov 24, 2010 | 11:28 AM
bjr001's Avatar
Hello,
There is no CEL. I checked the lines and did not notice or smell any gasoline. Though if this were the case I would think I would constantly smell gas. I only smell gas after I fuel up and then start the car for a couple of minutes. When I remove the gas gap there is always a sound of pressure releasing.
Happy Thanksgiving
Old Nov 24, 2010 | 02:36 PM
Thumbs up ** Happy ThanksGiving **
Eat Turkey and then Start all over again on your problem..
Angelo
Attached Thumbnails Gas smell in cab when I put gas in tank-imagescazfs46y.jpg
Old Nov 25, 2010 | 12:05 AM
IH8SPM's Avatar
Check the evap hoses in the engine compartment for dry rot or heat damage.
Elie Eyebrow
Jul 7, 2013 07:20 AM
waqarali
Oct 11, 2012 03:01 AM
edgar6190
Jul 9, 2012 06:05 PM
redaccordcoupe
Aug 1, 2008 08:01 PM
periapt
Mar 19, 2007 07:38 PM
