Gears
Old May 26, 2013 | 09:15 AM
Jessab's Avatar
Question Gears
Hello All,
I just found out that my 2nd gear is all chewed up on the countershaft and mainshaft. I was wondering where can I purchase gears for a H2U5 honda tranny. I can get one from the junkyard but really do not want to go there and mess with a tranny. I have to pull the part. Any suggestions.
Old Jul 14, 2013 | 04:40 PM
Jessab's Avatar
Hello All,
I got a donor tranny from the junk yard. The mounting bolts were broken so I swapped the top case. Now that I have everything back together the gears will not move into second gear without some maneuvering. Any suggestions!
Old Jul 14, 2013 | 04:54 PM
Does it grind when you try and put it in? So you completely ditched your old transmission and are working with a junkyard transmission now just swapped out the case?
Old Jul 14, 2013 | 04:59 PM
Jessab's Avatar
It does not grind. I have the tranny out of the car. I have not put any fluid in it as of yet. I was just moving the gears to see if they work or not. I still have to old tranny, I just swapped out the top casing. I could not find a replacement for the second gear that was chewed up. It chewed up gears on the main and counter shaft.
Old Jul 14, 2013 | 05:00 PM
Jessab's Avatar
I don't want to put it in and then have to pull it out again.
CedarCanoe
May 26, 2006 08:47 PM
nygamble
May 1, 2006 07:51 PM
HondaLawgik
Apr 18, 2006 02:28 AM
cache
Apr 16, 2006 04:43 PM
